usesunblock
Information: - HTC EVO 4G LTE on Sprint. Was running Android 4.0.3, HTC Sense 4.0, and basically default on everything else.
This morning I rooted my phone using the RegawMOD method. It took a couple clicks and I was good to go. Phone was working as normal, and I had superuser privileges.
Tonight, I tried to install the V6 Supercharger mod that was supposed to make my phone blazing fast. It required that I get JellyScreamPatcher first. So I ran the JellyScreamPatcher on my computer with the phone plugged in and it seemed to work.
I took a break to make dinner and do some stuff. Anyways I tried to run just a normal facebook app on my phone and it crashed. I thought that was weird and figured maybe my phone needed a reboot. I tried to do a reboot and the phone did the htc quietly brilliant logo, then the sprint logo, but got caught at the beats audio logo screen and never advanced.
Went into recovery (Team Win Recovery Project v2.2.1) and tried to do a factory reset, and a whole bunch of other things to no avail. The phone still gets stuck at the same screen. Also, I am unable to get it to be accessible on my computer again. It used to say HTC EVO in My Computer when it was plugged in. Now it just says Removable Disk and when I double click it just says "Please insert a disk into drive..."
I'm able to access recovery mode. Is there anything I can do to fix this?
Edit: When I try to power down in TWRP, it tells me "No OS Installed! Are you sure you wish to power off? And now it only takes me to the "HTC quietly brilliant" logo.
