Firstly, I know you hear this a lot, but, thank you scotty85! Your guide was easy-as-pie and I had absolutely no problems rooting my Rezound. I've flashed the Recovery you posted on your guide and it worked like a charm. Thank you.
Secondly, to anyone that can help, I'm aware of how to flash kernals and ROMs (I'm pretty sure), but the problem is finding them. Every one I've tried to download so far have been dead links. Does anyone know of a place that is reliable to download ROMs/kernals? Does anyone have any suggestions?
To sum it up -
I'm rooted. I'm using the vigor recovery. I've installed su. I am 100-percent sure I'm rooted. I'm just stuck on which kernal to use exactly. The ones I was going to "test" have dead download links. I haven't even tried a ROM yet.
To sum it up -
