Root Help Rooting in Houston
For whatever reason, i can't get the droid x to root.
Anyone already houston?
Have you seen the video that DiegoMejia made? http://androidforums.com/all-things-root-droid-x/130212-video-root-droidx.html
I haven't rooted the X (yet) myself, but have read through the instructions and watched the video and it looks fairly straightforward.
Maybe post a specific issue in the above thread or in the http://androidforums.com/all-things-root-droid-x/130116-how-root-your-droid-x.html thread and someone might also have run into the same problem and solved it? Good luck!
edit: also, if its adb and/or USB connectivity issues you are having, you might want to check-out this thread for rooting directly from your phone: http://androidforums.com/all-things-root-droid-x/131395-how-root-without-adb.html
