Been looking everywhere for how to root Lg Stylo 2 on 6.0.1 marshmallow please can anyone help me carrier is boost Mobile
Allegedly you can root with kingroot but you will have to enable oem unlock in developer settings and oem unlock via fastboot.
I have the Metro PCS Stylo 2 and KingRoot does NOT work. I have enabled oem unlock and unlocked the bootloader with fast boot, also usb debugging. KingRoot just tells me no methods available then shows me a number of people who have requested root and says the number isn't enough lol. Eventually it will happen.
I might look into building a twrp but redoing my machine now so don't know if I will get around to it.
after second reboot lost rootI got root using king root and rebooted and still have root
Try king root it temp but can get rid of the bloat wareMine is Virgin Mobile and it's a LG Stylo 2 LGLS775 I cant find root anywhere![]()
Did you try the newest version?I tried King root, no go![]()
Did u take the system update before trying the kin root?Yes ,,,i think its the new version of king root, its version 4.95 from king root web site. It wont work on my LG Stylo 2 LGLS775 from virgin mobile.
It only gives u temp root thoughAllegedly you can root with kingroot but you will have to enable oem unlock in developer settings and oem unlock via fastboot.
OK thanks now what does that do when unlock oemThe command is
fastboot oem unlock
