lol scary and i typin basically the same thing again![]()
I tried the replace rom.zip trick in FASTBOOT USB mode
It's doing some interesting things. It said waiting for bootloader then loading bootloader err something similar to that
then it said erasing user data
Now it is Sending......
It popped up 22% done then I got ERROR[140]BOOTLOADER VERSION ERROR
Give me some time to check out what scary posted.
Well, that's too bad...
Okay, let's try eu1's second item to try. Go ahead and do a "fastboot oem powerdown" (I think that's right) to shut your phone down without having to do a battery pull.
Then, if you think you still have enough battery charge left, do this:
1. Get yourself back to the Command Prompt, and make sure you have access to the "adb.exe" utility. You can do a "dir adb.exe" to make sure its in the same directory as your fastboot.exe utility is.
2. Power the phone on as normal, but try issuing "adb devices" command repeatedly while its booting, for at least as long as you think that its hanging again like when you first reporting things in this thread (probably just a four or five minutes should be more than sufficient).
Note, you can use the up-arrow key to recall your last command and just hit the return key to re-execute it.
Let us know if you actually see anything from "adb devices" (like your device ID like you reported before from the "fastboot devices" command).
If you do get a device name from the "adb devices", go ahead and try "adb shell" and let us know.
Cheers!
WHICH PB00IMG.zip FILE ARE YOU USING?
(Yes, I am shouting - it's important!)
I am using:
Eris_LeakV3_v2.36.605.1_PB00IMG.ZIP
renaming to rom.ZIP
yikes!the leak v3 isnt going to give you the s-off bootloader![]()
when youre charged up,try it again... and this time use the root rom. Eris_RootROM_v2.19.605.1_PB00IMG.zip
PB00100 XC SHIP S-ON
HBOOT-1.49.0000 (PB0010000)
MICROP-0111
TOUCH PANEL-SYN0104
RADIO-2.42.01.04.27
Feb 8 2010,00:08:56
I can't seem to find adb.exe
I typed "dir adb.exe" in the same directory as "fastboot.exe"
Driving right now. Away from keyboard for 30 minutes.
.Thank you Scary!
I tried "adb devices" while the phone was loading and I didn't get anything.
"List of devices attached" over and over with no devices listed.
(by "loading" I mean turning on the phone by pressing the power button only)
It takes a special kind of person to destroy a perfectly good phone, and then be itching to see how much damage he can do to the next one. Maybe some day I'll know enough not to destroy my phone, and I can help someone the way you all have helped help me.
