HELP! Start up problem
Aerror
ok so, i would enter download screen by pressing start, down, and up button... when its in downloading screen it automatically shuts off and starts vibrating every 3 seconds please help ! thank you.
Welcome to the forums Aerror:hello:
What is it you are trying to do. What is the model number of your phone?
Hi thanks.. the problem is my phone would not start, i would turn it on, it would load half way then completely shut off and starts to vibrate every 3 seconds.. the model of the phone is SGH-T989
Hi Aerror. I saw another thread today where several people were having a similar problem but no solution.
Try pulling the battery and leaving it out a few minutes then restart.
Try some compressed air and blowing around the power and volume buttons.
I don't know if it will help, and if it does you will have to reinstall all your apps, but you can try a factory reset in recovery. If you don't know how,
Power off your phone again. Hold both volume buttons and the power button at the same time. When the phone vibrates, let go of the power button but keep holding both volume buttons. In a few seconds you should be in the recovery menu. Use volume buttons to move up/down and power button to select. *if power button doesn't work, use your home key*. Go to wipe data/factory reset and select it. Next, select format cache partition. Now select reboot.
I had that problem once. Sometimes with this particular phone, the power button gets a little stuck, causing the repeated vibration. The only fix I could find was to pull the battery. It worked fine after that. I have seen threads about this issue, I think on xda, but I can't find them now.
