Root Help, stuck in a boot animation loop??
hey guys
im running skyraider vanilla
tried to add a notification bar
now it is stuck looping the skyraider animation n the dinc eye just going back and forth between them
what to do??
hey guys
what to do??
if none of that works, i.e your back up doesn't load, do a factory reset, it will completely wipe everything off of your rom and put it back to stock.
Doing a wipe/reset in clockwork isn't working for me. It's like nothing changed. Still the one boot animation I had, and still the same boot loop.
My girlfriend is having the same problem. Both running Skyraider 3.5. Factory wipes are not working. Skyraider is still on and nothing changes. Help?
Ummm, not exactly.
OP download another rom and get it on the SD card and flash it if your backup is gone.
It doesn't put it back to stock out of the box, but stock when you first installed the rom and wiped all the cache. I've tried it, it works.
