Hi,
I understand that this thread is in wrong forum but I need a quick response, so request the mods to not move this thread immediately.
I have been using CM Nightly of 15Jan 2014. Today, I tried installing Nightly of 30Jan2014 through
Clockworkmod Recovery 6.0.2.3 but the installation failed with error:
set_metadata_recursive : some changes failed
error is /sdcard/0/Cyandelta/cm-11-xxx.zip
Status 7
Installation Aborted
Now, the tab is in a bootloop at Samsung logo and sometimes it boots into Recovery.
Please suggest a solution.
Thanks
Status 7
Thanks
) which had saved a copy of the su binary in the /system partition with an immutable status that keeps it from being removed or altered which subsequently causes the set_perm_recursive command to fail.
