senor.ehlert
Hey Guys,
I messed up pretty big. I meant to downgrade to the official 2.2 since I was having some problems but messed it up. I was going to use the file found on this forum which has helped me before. But of course I stalled the wrong PB31IMG.zip file (my fault for not renaming or removing it). This is PB31IMG.zip is a very old file and one of the first downgrades I found. The file installed fine but after it keeps booting me into HBoot and wont start up the actual ROM. I see that it has also downgrade my radio to 1.0x
So basically my question is what did I do? Do I just need to install a ROM and will I be fine? Is it ok to install the upgrade radio? Is it ok to just install the PB31IMG.zip from the 2.2 downgrade forum, and will it hurt anything?
I know I messed up and thanks for the help in advance.
