welcome to the forums!!!!!!!!!!!!!!!!!
when you say stops do you mean that it goes from white screen to the boot animation and then over again?
try pulling out the battery, wait ten sec and then put it back in and boot up.
if that does not work then you may need to do a hard reset.
power off (or pull battery) then press and hold power+vol down. select clear storage. this will delete your data and apps and returns your phone to factory settings.
