Root Help stuck on 5.5.866
tbone1319
Hello all, i need some help. I was on the 5.7.893 leak and decided it would be a good idea to get on the "right path"...well not such a good idea! I followed the guide to return to stock and root and forever root and install cheesecake. All was fine till i installed the .866 update. It fails to install with the (triangle !) then the phone reboots and a error of update failed. So now im stuck on .866. Will the one click method work in my case? I cant find a download with megaupload being down and all the other links dont work. PLEASE I NEED HELP!!!
Go to the thread how to flash 5.5.893 with rsdlite. This will install the lastest OTA
well flashed in rsd and im getting an error...Please check input file. Either xml format is wrong or image files assoiated with it are missing
Hey tbone. If your getting to the triangle that means your doing it correct. When you see that just push the volume buttons and that will put you into stock recovery. At that point flash. 893
Yes I can get that far with no problem but when it installs i get an error. dose someone have the 893 file that they can send my way
Ok this is what happens when I apply the update via it's reverted back to stock all appear and I am currently on 5.5.886.ST.875.Verizon.en.us
Finding update package......
Opening update package.....
Verifying update package.....
installing update....
Verifying current system....
Assert railed: apply-patch_check ("MTD: boot : 8388698: a3dc7f949d7fffbd64c8ea1ad19dc9dc9640deb12:83888608:066c0cde529a79b136c28d694a5978a2")
E: Error in /cache/ Blur-Version. 5.5.886.xt875.Verizon.en.us.zip
Then the phone reboots then...
Update status
The software update failed
Update status
I think you should reflash the 5.5.886 file with rsdlite. Let the phone reboot and then either see if you have an update waiting or flash 5.5.893 in rsdlite.
