Hitch_Itch
Member
I just tried to backup using rom mgr. I wanted to do this because its a good configuration setup with my current skyraider 3.5 rom
my screen is in clockworkmod recovery screen, it shows the following,
there might not be enough free space to complete backup...continuing...
backing up boot...
backing up recovery...
error while dumping recovery image!
/tmp/recovery.log was copied to /sdcard/clockworkmod/recovery.log
please open rom manager to report the issue.
I cant get off this screen, at the top I have
reboot system now
apply sdcard:update.zip
wipe data/factory reset
install zip from sdcard
backup and restore
mounts and storage
advanced
reboot system now is highlighted, when I press the power button, nothing happens, I can use volume up/down to highlight the other stuff
i dont know what to do, so before I do the WRONG thing and brick it, someone tell me what I need to do
Help,
thanks
Ken
backing up boot...
reboot system now
backup and restore
mounts and storage
advanced
Help,
thanks
Ken
