With unrevoked 3.21 you don't need to downgrade the HBOOT, did you already get the goldcard.img emailed from the GC tool?
If the patch isn't working, delete the goldcard.img and redo the GC tool again and get it to email you another one, took me 2 tries myself. Also some people say some SD cards are reluctant to work.
Are you making sure you have formatted those cards in fat32?
you have creating the cid when the sdcard is formatted?
you are booting with the sdcard inserted and then getting CID without mounting?
you are flashing the CID to the SDCARD when in the device and mounted as a drive?
make sure you rightclick the gold card tool and "run as: administrator"
Quote:
I'm not sure what you mean here. I insert the sdcard into the card reader, not the htc desire, and then get the cid for it
do as follows
1. go into settings>sdard and storage> click unmount sd card > click format sd card
2. go to settings>applications>development> tick usb debogging
3. connect device to pc and load up goldcard tool as administrator (run as)
4. click get CID then click on link and past the CID from the top box
thats where you are going wrong
the CID is unique to the desire
in order to get the correct CID using the goldcardtool you need to be booted into the device with usb debugging enabled and the SDCARD inserted into the device but on chargeonly, not mounted
Then after you get the new image from your email, patch it by enabling usb disk drive on the device then click refresh and load image, patch
should work
Gah. I didn't know that
