Root HELP!!! Troubles Unrooting Evo 4G
trncwllc
I Think I Followed The Unrooting Steps Perfectly From ROOTING For Dummies Guide.....the Gingerbread Edition, But Since There Is An Error I May Not Have.
When I Turn My Evo On I See The Regular "HTC Evo 4g" Welcome Screen Then It Takes Me To A White Screen With 3 Aliens Skateboarding That Says At The Top
SUPERSONIC EVT2-3 SHIP S-ON
HBOOT-6.17.0001
MICROP-041f
TOUCH PANEL- ATMELC03_16ac
RADIO-2.15.00.0808
Mar 8 2011, 17:02:15
When I Select Bootloader It Starts Finding A PC36IMG.Zip File.I've Tried Many Different PC36IMG.Zip Files & Got The Same Result. It Seems Like It's Loading Up, But Does Absolutely Nothing.
When I Select Recovery It Takes Me To Revolutionary CWM v4.0.1.4
I Have No Idea What I Can Do With This
PLEASE HELP!!! PLEASE TELL ME MY EVO ISN'T DONE FOR GOOD
HBOOT-6.17.0001
MICROP-041f
RADIO-2.15.00.0808
welcome to the forums!!!!!!!!!!!!!!!!!!!
moved you to the rooting section.
have you tried this ruu:[ROM]RUU_SuperSonic_GB_Sprint_WWE_4.53.651.1_Radio_2.15 .00.0808_NV_2.15_signed.exe
basically you need to have usb debugging on on your evo. then run the exe file on your computer then plug your phone in when it tells you to.
Thank You For Replying, But I Can Not Turn My Phone On To Turn On My USB Debugging Is There Another Way TO Turn On My USB Debugging?
You didnt mention that in your original post. :D
Are you unrooting for warranty service?
Does it find the correct file and start to load it? Are you sure you have it named correctly (NOT .zip.zip)
I had the same problem as you where it would not actually update anything. Unfortunately the thing that ended up working for me was the link that ocn posted for you. If you can't turn boot the phone that method wont work.
It would load the file, said it was extracting, and then just go back to the menu like nothing happened
Yes, It's Right. The PC36IMG File Look Like It's Loading Then Does Nothing
How long are you waiting? Also do not flash this. When you go into h boot it should find the file and ask if you want to update select yes and let it do its thing. The first time i did this it seemed like nothing was happening but then i seen a progress bar at the right but its hard to see.
Im not saying its working just makeing shure you are waiting long enough.
Are you getting any errors?
