Root Help! Usb plug in wont work
sm0kex
I have no idea what i did but everytime i plug the damn thing into the computer it always wants to charge i even bought a data cable :mad: :confused: its on internet connection trying to update smh
Have you tried going to connectivity and Changing it to USB mass storage?
I'm a thug cause I give hugs because you can't spell thug without a hug.
Yeah it's prolly the cable. You need a LG cable or maybe even a Samsung cable.
I freaked out the first time I saw this happen for myself. All over the damn cable. Couldn't believe it.
This happened to me (and my wife's esteem) several times too.
When this happens I simply reboot the phone and the problem goes away.
you need an lg wire then. lg specifically doesnt work with all cables
WRONG! USB is a standard, if the cable is up to spec it will work. The only thing is some are made to only supply power (AT&T replacement cables for instance). In fact I have never used the cable that came with my Esteem since I have a pile of other ones that I use.
