My battery drains pretty fast, and I have it on power saver, I just dont know what else I can do. I use task killer, and I turn down the brightness, any other suggestions?
Try using it less. Your a moron battery use isn't rocket science.
Make sure your vibration notifications are off. Lower brightness and turn WiFi. Gps. Bluetooth when not in use. That's all you can do. Invest in extended battery.
I mentioned brightness earlier, and I figured things such as bluetooth and gps would be obvious. You need some people skills and grammar lessons. It's "you're" not "your."
