Alright, I give up! I have been everywhere (with exception of the CORRECT place!) looking for the method by which I make my ringer audible...! Crazy!![]()
not sure i understand what you mean by audible
if you want to use a ringtone you can do 1 of two things
store it on the sdcard under media/audio/ringtone
or you can place it in system/media/audio/ringtone
make sure to reboot and wipe cache and dalvic if placing in the system folder
Sounds like you need to reflash the rom unfortunately. Make sure you wipe really well
As far as rom I say try several different ones until you find one that you really like and have no issues with
Right, it's a complete download. You don't need to flash two rom files. >>AH I thought that MUST be the case! Thanks for confirming.<<
I've flashed CM7 a boatload of times....when nightly releases were literally nightly releases, I was updating it virtually every day and never had that type of issue. Only two things come to mind, a bad download of the file, or bad wiping through recovery. Make sure you're running Amon RA 2.3 or higher and when doing the initial flash of the rom that you wipe everything except the SD card.>>I wiped all recommended items per Rooting For Dummies....Gingerbread three times THEN ran the SUPERWIPER .ZIP three times so I'd think this puppy is mighty clean this time!
Just a thought though, are you integrated with google voice?>>No.<< Do you have google voice installed on CM7?>>No.<< Maybe that's causing issues. If you aren't integrated with GVoice, then I honestly don't know why your phone wouldn't be ringing if it's not one of the two issues I listed above.>>My phone is currently acting proper now after the new flash!.<<
