Needforspeed
On my notification bar it says i have a max of 4 bars when before i had 6 as usual and they are not lighting up also only 3 of my contats are showing up
To restore apps only, you can do menu->batch->Restore missing apps with data (or Restore all apps with data). I recommend, though, that you go to Backup/Restore, and manually restore only the apps that you need, It's cleaner, and will help you avoid conflicts. Do not restore system data (settings) when going from sense to aosp. It will break things, as you've seen.
To change the notifications panel widgets, you go to CM settings, I believe. It should be under the normal settings menu.
Ok my prl has the latest update but I can't update my profile it says can't update profile
