Deleted files can still be recovered, but you need software for it. Also it is not 100% guaranteed. You might get lucky and recover all of it. The main thing is NOT to use the card you want to recover files from to prevent further 'damage' to the file being recovered. Since it will overwrite the sectors that most recovery software will look at to try to rebuild the file.
Some free recovery programs:
Recuva
MiniTool Power Data Recovery (up to 1 GB)
EaseUS Data Recovery Wizard (up to 1 GB)
