I have an HTC EVO 4G form Sprint and I have some how moved the grey phone, more apps, and add bar from the bottom of my screen to the right side of the screen. I really hate it and have no idea how I did it. Do you know how to get it back?
not sure if this is the solution you are going to want but my best advice would be to do a factory reset of the phone. Please make sure you backup all your contacts / sms / mms / and other stuff before doing a factory reset. You will probably need to format your SD card as well so again make sure you have a good backup stored on your computer. If you have a Google email acount and you are synced then your contacts should start showing back up after you reset all your accounts. Before doing the reset you can call sprint and see if they can tell you how to fix it but more than not they will tell you the same thing.
This worked for me.. use menu then go to settings then go to display turn off auto rotate then go back to main page and hold the power button down on the top of your phone when you see power off airplane mode and restart just click restart it took me a long time to figure this out but it should work has for me a few times
