Root Help with Go sms pro
I just found out that SlimBean does not send pictures at all. I searched here and XDA and all I've found is to use go sms pro. So I dl go sms pro from the app store and I feel real stupid because I can't figure out how to use the darn thing. It does not have any of my contacts from my phone and when I try and add a contact it does not save it. I tried sending a regular text and a mms but nothing goes through. I've searched here, XDA and google search for a how to but the ones I've seen show the contact list is updated already, I can't find a settings menu anywhere in go sms at all.
well i use go sms pro and if you swipe to the left you get sort of a menu. and if you swipe right you get your contacts......i'm on beanstalk and i do not have any issues with it so far.
it might be a bug or something. try unistalling the app.
f that does not work then try and re-flash your rom. first try and wipe only dalvik cache and cache and re-flash the rom or you can start over and re-download, re-wipe everything, and reflash the rom. i ad to do this with beanstalk as i could not send anything. but a fresh flash did the trick for me.
