A akazabam Android Expert Apr 7, 2011 #27 I wonder if maybe you should try flashing an actual RUU. Let me do some more research on this one tomorrow.
I Ivansandroid Well-Known Member Apr 7, 2011 #28 akazabam said: I wonder if maybe you should try flashing an actual RUU. Let me do some more research on this one tomorrow. Click to expand... Ok thx. There is a sd card usb mount fix on the xda site. Do you think it would help my situation?
A akazabam Android Expert Apr 7, 2011 #29 That one in particular, the way it is described, won't, but there are other things to try. I'll get back to you if someone else doesn't first.
I Ivansandroid Well-Known Member Apr 7, 2011 #30 akazabam said: That one in particular, the way it is described, won't, but there are other things to try. I'll get back to you if someone else doesn't first. Click to expand... OK
