Root help with htc evo wireless tethering
jusblaize
andriod forums,
my htc evo is rooted, i have titanium backup and you need root for that application to work so my phone is rooted. i downloaded the wireless tethering app. succesfully but when i turn on tethering it the down speed stays at 0.4kB, 0.0kbps and the up speed stays at 0.1kB, 0.0kbps. it also used to pop up as a wireless connection but it wouldnt connect. now i just re-downloaded the app and it does the same exact thing but the wireless network doesnt show up. any suggestions?
justin
i have the "wireless tether for root users" app. there isnt a 2.0.5 according to the market. are we talking about the same app?
Try a different version maybe... check the connection settings also
I am using pre 8 or something like that...don't remember. I have noticed some versions work better than others and that this varies from phone to phone
And just a little FYI....and I may be misunderstanding you, but those numbers that you see on the wireless tether app are NOT speeds. The are just the amount of data that has been downloaded or uploaded....
true that...I didn't even think about that when I read his post
alright so i downloaded the 2.0.5 pre11 and i tried it, it didnt work
I had similar issues. So...try this: Delete ANY profiles you may have to the phone on the computer you are trying to connect to. Change the SSID to something different (I use droid) and then turn OFF any and ALL encryption on the EVO...then try and connect. If it works, then you may have some issue with the encryption...there are other threads that discuss this.
