Finally I managed to detect the problem and it appears to be related to the com ports allocation on my system, as well as registry leftovers.
I've been running another sync software from Sony Ericsson and it had taken up the needed comms resources for the HTC sync.
As there's no point in trying to manually reassign the ports I uninstalled the SE software and performed a thorough manual cleanup of the registry. You need to also delete all HTC Sync related keys from previous installation attempts to perform a "clean" install. Be careful not to delete anything else important that has the letters "htc" in it!
After cleaning up the system from other sync software and the registry cleanup you also need to make sure that you have the latest InstallShield script running (ISScript115.msi). This should be located under \Program Files\Common Files\InstallShield\Driver\1150\.
Next installation attempt was successful and there was no Error 1713 anymore. HTC Sync now works fine.
However, the steps above could prove useless in other cases, but I think it's worth the try.
Hope this is helpful...
My only other computer is a mac and I really dont want to reinstall windows.
