Help help with incredible
rankman
I bought an incredible off eBay an after I activated it the 2.2 update downloaded immiediatley and after it completed the install now button did not work and after a min I hit the option on the right . Havent seen update since. Should I be worried?
Go to menu -> settings -> About phone -> Software Version .
If it says 2.2, it installed and you're all set. If it says 2.1, hit back, then at the top select "System Updates"
I did that for the past 4 days and nothing. Is the ota push done? If so what's that mean for my phone and what should I do.
Honestly, I'm not sure. I think your best course of action would be to contact Verizon and ask them. Most of the users here (myself included) had already rooted and didn't get/accept the Official 2.2 update. Since it's been a couple weeks I'm sure they'll have some options available to you.
