Im wondering if theres an app that I can set to go off say every 20 minutes or another time determined by myself. Ive had a look in the play store and couldnt see anything that would do what Im after, maybe I didnt search using the right words.
(please take no offense at the title of that web site!)
Do you mean like an alarm clock? There are several you can set reminder alarms throughout the day. Like Alarm Clock Xtreme and Alarm Clock Plus
Your device has a stock, quite robust alarm clock.
How to Use Your Nexus 7 as a Clock - For Dummies(please take no offense at the title of that web site!)
Perhaps you mean some other function not provided by that default app.![]()
I think you can setup either of those apps to do that and probably like Frisco said, the stock alarm you already have. I don't know how easy that would be on the stock alarm. You might check our reMind Alarm. It looks like it can be set easily for repeat alarms throughout the day..
