I would have agreed with you untill I was using Mik3.0 and above. I had the some problem. It would be fine at 1st then over time would slow down on all wifi or mobile data. Finaly i did speed tests and it only was download not upload. Clearing dalvik cashe would make it work back to normal but would slow down as time went on. seemed to be the amount of data used rather than time. Im in no way familer with how the rom or kernel affects or uses the data IE temp files or something but it seemed the more that was downloaded the more junk was left somewhere in the system and it took longer to process maybe? Again I may be totaly wrong but all I know was it did not happen to me on the older versions and only happened on mik3.0 and 3.11. I just made it a habbit to wipe the cashes every couple days. At one time in the beginning I had a thred about this problem but that was a while ago.Wait you have Mik rom?!!???!?!?! Is your wifi slow everywhere you go or just on your own, try to reset your router. A rom should have nothing to do with wifi speeds. And I don't know why anyone would assume it would.
ocnbrze is other rom for evo with JB or ICS because the ones u give me they are no working right thakx
