Root Help with NinjaMorph Please!
Helenoftroy08
I am running a Pete's virgin deodexed Froyo FRF84B. I have my Droid themed, and am trying to change some program icons using ninjamorph. The program actually will replace the icons inside of the apks, and when I return to the folder where I am trying to change the icons they appear changed there. But the icons do not stay changed. Once I exit the program, the icons are the default ones that I m trying to change. Ne suggestions? Thanks guys!
Hmmm...I don't use Ninjamorph but as with many theme related changes, the cached images, fonts, colors, etc. are usually seen until you perform a reboot. Have you done that yet?
Yep, and after a reboot, they are back to the default icon even, where they appeared changed initially! I'm stumped:(
