Root Help With Power and the X button.
Oracle646
Hey Frienddsss
So when I am trying to boot into recovery mode, and I press the power button and an X and it show a triangle with an ! in the middle and the phone below it....What is that and how do I fix it?
Why are you trying to boot into recovery? If you're getting that image, there's no recovery (SPR or Clockwork) on your phone. Are you trying to root for the first time?
No. It should already be rooted. I can restart into my original ROM I have on there. Just not SPR..
How can I get it back? SPR that is...?
So when you boot up its still the rom and you still have root access?
If you do just download rom manager and use that to flash SPR again.
If not you will have to use RSD Lite to flash the SPRecovery sbf file.
edit: it is possible to flash the stock recovery although I dont know what anyone would do it and its not something that you could do on accident
If you see THAT triangle with ! in it, you aren't rooted...
LOL then never mind..I mean at one time I was, but I went to a nandroid OS from before, and I guess it was never rooted.
Can I ask you one other question(s)...no one else is responding to them.
HTML:
http://androidforums.com/roms-droid/135022-liquid-frozen-yogurt-v1-1-rom-theme-release.html#post1252668
This is the ROM I want
I want this ROM and I understand how to install it in the Root of the SD card, but how do I install the Theme?
And also, with all the Kernals in the link that he gives for the recommend downloadable ones to download....which ones do you download or should I? Or all of them? And where do you put them?
This is what some guy wrote back:
You install the theme as a zip from your SD Card using ROM Manager, same with the kernels. You may want to let the ROM settle for a day or so before you install the kernel. If you have SPRrecovery, rename as update and flash from recovery.
My question is this:
Ok is there any ROM manager you suggest? And do I just open that theme in the ROM manager as well as the Kernal (there is a link in the web page I listed)
Thank so much!
