well i'm no doctor so can't help you out with you dying and all
but if you are using underworld and your phone's battery is draining fast then you might want to consider moving on to a different kernel. now also keep in mind that you can tweak the kernel by over and underclock the kernel as well which might improve your battery life. also setting the kernels governor might also help out with battery life.
and what last thing on kernels, they all react differently on different phones. what may work for you may not work for me. also give the kernel a few days before moving on to a different one.
