Root help with root
kevin1313
Need help...
Rooted my phone using unrevoked. Had to do a hard reset to phone. Tries to root the phone again, unrevoked says it was a success but when i try to do something( use wireless tether) it asks if my phone is rooted? How to solve this problem??? Thanks
Need help...
It may have failed to root your rom. Do as Ocn suggested and check to see if you have s-off. If so, you can do the rest manually if needed.
