zanthal
Member
I've rooted an LG Optimus V before, but either a few things have changed since then or I'm forgetting something. Either way, I have curiosities and concerns that I hope someone could clarify for me, essentially, break it down into layman's terms for me.
I'm looking at two different ROMs, Mobster ROM HD and Mobsterz/unSENSEable v1.1 ... if I'm not mistaken (which I'd greatly like to know if I am) they require the same kernel be used during flash
They look very much the same, and it seems the only difference is the removal of this Sense (another thing of which I'm unsure of)
Mobster ROM HD requires S-OFF, Mobsterz/unSENSEable v1.1 can be done with 4EXT.
Any and all suggestions would be helpful, but the question I need answered specifically, is can I follow the "Complete Newbie's Guide to rooting and flashing Evo V 4G ROMs/Kernels using fastboot" to flash either of these ROMs (instead of the stock ROM listed in the guide), or is there more to it than that?
Thanks
UPDATE:
I read about HTC Sense 4.0 ... now that I know what it is, should I go with the true dual core ROM that keeps it, or removes it? I figure HTC won't have a good rebuttal listed.
Thanks
UPDATE:
arty:
