Root Help with rooted samsung stellar
i got it thankk you!! and ihave one more favor to ask? itskinda big feel free to sayno,, but i waant to cyanmod, but my device isnt listed, could i use sg3 one? or can you help me i have no idea what im doing lmao, or give me a good rom for my phone
No problem at all, I won't say no, ever:p
If your device is not listed as compatible, dont flash it...bad things can happen when you try to flash a rom that is made for another device!
The rom I linked is the only one I found so far...didn't search real hard, but wasn't looking for other roms...just something that would help you with your mms thing.
Let it be said that I am not familiar with your device but some things are similar to mine.
I think the simplest thing to do is download that rom.
Double check the md5 checksum that is posted so you know it is a clean, not corrupt, download.
If you are not sure on how to check that, I can provide a link that better explains that. But in all my time of downloading stuff, I have not had a bad download (corrupt). Others have. So it is possible.
Make a nandroid backup in recovery. That is a snapshot of your phone's current state...like a game save...if anything goes wrong with the flash, your can restore your phone from that backup you made.
Once you have the rom downloaded and on your sd card, you can flash it from recovery.
Do you know how to get into recovery?
I know, alot of questions and alot to absorb here. sorry.:)
i am so lost,lol im sorry very new to this. But the thing i got my messaging out of? thats the rom. it is downloaded so a step by step walk through is much :confused::confused::(
i have no idea how to put that rom on my phone
basically:
1. download the rom file (do not extract it, leave it zipped)
2.move the file over to the sd card
3.boot into recovery
4.make a nandroid backup
5.wipe dalvik cache, cache and data(factory reset in recovery) and system(if available)
6.select install zip (or something similar)
7.find the file and select it
8.reboot
now i do not have your phone nor do i know what recovery you have, so this is a generalization.
if you can let us know what recovery you have and the menus you see in recovery, i might be able to help you better.
