xDRxZOIDBURGx
Alright here is my situation - I cant find the damn preferences menu on my phone! I press the menu key when on the desktop but I dont see a preferences button. Where the hell is this thing?!
What setting exactly are you trying to get to? I.e. ring tone, wifi, screen
I hope Teddy was able to help get you back on track!
Im trying to get to video and/or display prefrences.
How's the CHINA TELECOM thing working for you,P1zz4guy?I hope Teddy was able to help get you back on track!
I guess I shoulve been more specific, what are you trying to scrfeen/display to do?
It might be that the acsend doesn't have a dedicated gpu and might not Bea screen problem :-( its the same reason it won't play angry birds.
Nope no option for that sir,![]()
Lots of ppl are going to be jealous that you can play angry birds lol
Ok I bought iDemolished and when I went to play it I found that it was graphically messed up. I thought it was just the game but then today I downloaded an active wallpaper that shows snow falling in trees and the damn snowflakes are doing the same thing! I want to get to the preference menu so I can try to figure it out.
And yes, I did try uninstalling and redownloading both applications - several times.
