Root Help with superuser
jhkboy7
i have recently rooted my fone and have super user bet when i installed titanium backup it says it does not have super user privelages.. when i click on super user its just black with nothing on it.. anyhelp plz? i do have super user privelages bc when i go in the terminal and type su it works..
Click on the "problems?" button in the bottom of the Titanium Backup app. Mine was doing the same thing and that fixed it. :)
Click the Problems? button in Titanium.
I did. :p And also, I think you aren't supposed to see anything in Super User other than what permissions you currently have for apps. Until you have permissions all you will see is a black screen. :)
it says
BusyBox works but the "su" command does not elevate to root: "whoami" reports "whoami: unkown uid 10079" instead of root/uid 0. I think your "Superuser Whitelist" system app does not work. Please check with your ROM provider..
i ahve no idea wat this means but during the acess i added these commands... even though it didnt say to (ya i noe im stupid)
su
/system/bin/cat /system/bin/sh > /system/bin/su
/system/bin/chmod 4777 /system/bin/su
btw im running stock sense ui
