Help with Yellow Triangle
13neo
Please help as I am extremely confused.
I have a new SG2. I did not root.
Everytime I restart my phone I see an Yellow Triangle with exclamation mark.
Now, as I understand, everyone who gets the triangle has rooted the phone.
Is there something wrong with my SG2?
Thanks.
if you have a yellow triangle you must be running a custom ROM /kernal
to get rid of this
download odin if you dont already have it entract it and open it
goto this page [25.07.2011][CF-Root v4.1] KE2/7/8, KF1/2/3/4, KG1/2/3 - su+bb+CWM4 - xda-developers
download a cf root kernal (the latest one will be ok )
once downloaded make a copy of it and on 1 copy extract it so you have a zimage
put that zimage on your phones sd card not your external one
ok so open odin then put your phone in download mode vol- middlebutton power connect usb from phone to computer wait til it says added press pda and find the cfroot*****.tar that you downloaded press start wait til complete
now find an original stock kernal (cant find link sorry )
open odin again select pda and find the stock kernal you downloaded
boot into download mode again vol- middlebutton power
click start wait to finish and unplug
now coming to the bit where you extracted the cf root kernal to a zimage
find the clockworkmod app
select flash kernal and it will show the zimage u put onto the phones sd card
i will say this once more dont put it on external sd
flash the kernal and your're done
when booting you wont see yellow triangle
now if you wish to flash another kernal without the triangle appearing again heres what you do
download cust kernal for eg ninphetamine 2.0.2
once downloaded extract to a zimage again put on PHONES SD CARD NOT EXTERNAL (LOL) open the clockwork app again flash
hey presto no yellow triangle
I will have to read your post a couple of times more to understand!!!
Thanks anyway. But my question is should I try to remove the triangle? Is there anything wrong with the handset?
yeah as slug said the triangle is just basically telling you that you are not running stock..
i only removed triangle so i could add a custom splash screen
if you mean you want to flash custom ROM !!!! yes you will get triangle but only on splash screen not notification bar
it is of no importance to get rid of the triangle . only if you want a custom splash screen
your're not exactly going to see the splash screen that often . well unless u like the look of it :)
edit : off topic . slug is there any reason why my sig will only show up on some posts and not all of them
Thanks.
Yeah.... I don't like it so I switched it off. :D <=== j/k
The real answer is that the forums are set up to only display users' sigs once per page, to maximise space for actual posts.
cheers chap ..
heres my thoughts on the s2 so far
its beyond awesome , wow , dogs dangleys .. and great battery life ..
and have not had half the problems i did with my htc devices lol
cheers chap ..
Great battery life.............you must be doing something right!!!!!!!
yes i had the desire .
had the phone 6 days now
minimum battery time 1 day 4hrs moderate 2 heavy usage
max battery time 1 day 22hrs moderate 2 heavy usage
htc desire 4-6 hrs moderate 2 heavy usage had to charge 2-3 times a day
