with apex 1.0 installed you will prob get a failed installation ,if you do you will either have to restore a backup you made before you installed apex and if you dont have the backup then you will have to flash the sbf then ota then reroot and install apex 1.3.1I just got an OTA asking to install and I am not sure if it is safe to install. What should I do?
I have:
Apex 1.0
Bootloader 30.01
System: 2.3.15
I heard that I need to update somehow to use the new Apex anyways.
Thanks for the help guys. I am just a little nervous.
lol beat me to it while i was typing!That update will fail. You need to roll back to a stock backup w/o removed apps, not deodexed to install the ota. Apex is deodexed with bloat removed so it will fail.
Do you create a backup (nandroid) of your stock setup before you removed apps or installed a rom?
If not, you'll need to sbf back to stock (2.3.15), the take the ota.
lol beat me to it while i was typing!![]()
no leaks will fail as well but you can try ,you may need to flash sbf then otaI have a backup before I used Flyx, but I am afraid that it is only the 2.2 leaked version. Is that still ok?
colchiro what class are you taking lol beat me to the draw againYou need version 2.3.15 that has no bloat removed and is not deodexed.
If you you don't have a stock/standard version, no OTA.
2.2 then ota straight to .340If this fails, I should SBF to 2.2 full and then use the ota updates. Or should I then SBF to 2.32 full?
was just gettig ready to paste quick draw mcgraw!Here's RSD Lite and latest moto drivers: http://androidforums.com/droid-x-all-things-root/232866-sbfing-back-2-2-a.html
I'm sure someone else is posting the link to flashing.![]()
yes but not as fast and if your batt dies during this you are out of luck!just a precautionJust curious as to why the battery needs to be at 80% to sbf if it remains connected to the pc. Wouldn't it continue to charge throughout the process?
its doubtful it would happen but possibly yesSo if my pc crashes durring a SBF flash, my phone is fully bricked and not even reflashing will save it?
