Help help
i just bought a huwaei ascend m860 how the heck do you make the song you just downlosaded your ringtone i cant figure it out
Welcome to Android Forums. I'll move this to your phone's section for you.
Go into your app drawer
find and open file manager
you will have two tabs at the top...one is your phones memory, one is your SD card...click the right on as that one is your SD card
find the download folder, open it
in there, you should find your ringtone....
long press on it, and click set as ringtone...
If you used Zedge to download a ringtone...
same thing, just go into the zedge folder instead of download, and inside there you will see a ringtone folder, and inside you will find the ringtone....just long press and click set as ringtone.
