I have anddroid 2.3.5 on my Optimus V. But I will not sync my Gmail acount for nothing. And also I don't have the Android Market any where on my phone. Please help.
Did you flash the gapps zip after flashing the rom? You need flash that one also when using a cm7 rom as the google apps are not included in the rom itself.
Go here and use gapps 20110613 Latest Version/Google Apps - CyanogenMod Wiki.
Once you've chosen a CM7 ROM and the proper gapps that go with it,and have them on the root of the sd card. Go into your recovery and do all these things(this must be done when installing a new ROM or restoring a backup)
1.wipe cache partition.
2.wipe dalvik cache(advanced section)
3.wipe data/factory reset.Now that your rooted YOU MUST NEVER USE THE FACTORY RESET IN THE PRIVACY MENU ON THE PHONE
4.format boot,system,data,and cache
5.go to install zip from sd card
6.go to select zip from sd card,chose the ROM first. It will go thru the install procedure. When done go back to step 6. and select the gapps.
When all this is done select reboot system now.
