Help Help?
Talk to me. Are you rooted? Do you have the stock ROM and Recovery? I have a script fix or two, plus there is an app called Market Fix, on the market that might work.
I have not rooted my Optimus 2X
So I guess no stock ROM or recovery (no idea what it is, sorry)
Since I can't download apps I can't download market fix.
All the help is welcome, so thnx :)
Have you tried going to the Play store Via the PC. They have a site that will allow you to download apps straight to your phone without having to plug it in to the PC. Download App Tyrant as well as the Market fix. In the future with App Tyrant installed you will be able to go back to an older version of any app that you installed. App Tyrant saves all installed app's in there apk form, you have to delete the old ones. They don't get deleted every time you update, so the good older apk is still there for you to install over the messed up new one.
Have you tried going to the Play store Via the PC. They have a site that will allow you to download apps straight to your phone without having to plug it in to the PC. Download App Tyrant as well as the Market fix. In the future with App Tyrant installed you will be able to go back to an older version of any app that you installed. App Tyrant saves all installed apalrep's in there apk form, you have to delete the old ones. They don't get deleted every time you update, so the good older apk is still there for you to install over the messed up new one.
I have already tried that still get the same error :(.
I'm going to try app tyrant thank you.
Duh! Put your sd card into your PC. Go here Latest Version/Google Apps - CyanogenMod Wiki and download the 2011028 version to your PC.
Download this Free File Compression Software - Easily Zip/UnZip Files & Folders and install it.
Go to the downloaded Gapps.zip and left click it to open it up. The Express Zip Software should bring up a pop up. It will have two folders, open the system folder. Open up the app folder. Extract and transfer the Vending.apk to the root of your sd card (not in any folder, just near the bottom of the list of folders).
If you have a file explorer/manager on your phone you should be able to go into your sd card. Long press or tap the Vending.apk, which ever one gives you the option to install it. Do so, it should ask if it's ok to install it over the old one say yes. Once it's install select done and exit out of the file explore/manager. There you have it.
Trying it out thanks in advance :).
Something else is causing the problem. You need to clean the cache from all the apps, the clipboard,etc.. Everything. Then go to the Browser and open it up and go to the settings and delete it's cache.
You do have a cache cleaner, right? If you do this will work for cleaning most of these caches.
