I'm talk about the whole phone factory reset:
1. Turn the phone off.
2. Press and hold the following keys: Volume Down Key + Power/Lock Key.
3. Release the keys as soon as the Factory reset processing screen is displayed.
4. Press the Volume Down Key to scroll to wipe data/factory reset . Then press the Power/Lock Key to select it.
5. Press the Volume Down Key to scroll to Yes -- delete all user data. Then press the Power/Lock Key to select it.
6. The phone will perform a factory reset.
7. Make sure that reboot system now is highlighted and press the Power/Lock Key to make the selection and reboot your phone.
