johnnyolivares
This thread is so people can post things they discovered about the Motion, for example I remember on my indulge if you held then move the status bar you could adjust the brightness.
Also I discovered that instead of pressing the camera button when taking pics you also can press volume +, it is a lot easier for me than just be guessing where the camera button is, I'm talking when taking pics of myself![]()
Also if you hold the menu button while at home you get Google search.
And I love the lock screen settings
Do you mean the "Settings" button, the one on the far-right?
Menu button=Settings button
Get enough helpful tips in this thread and I'll sticky it, including links to other members' threads (like this one: http://androidforums.com/lg-motion-4g/666320-hidden-safe-mode-lg-motion-4g.html.)
Also if johnnyolivares wants to, he can update his OP with all tips mentioned already in this thread.
You'd be surprised at how much better quality your photos will look if you adjust "Scene Mode."
For example, using "Incandescent" while indoors and "Cloudy" while it's cloudy outside makes a huge difference.
How do you change this?
How many posts til I can create a post to ask about which app actually works to give bluetooth volume boost without needing to root the Motion?
Thanks!![]()
I challenge you good sir. If I am correct that is the recently used app list not a task manager. Got to task manager Try using 5 different apps. Then close them with the task M. use another app to be sure there off. but you will still find then in the resent app list.But today I discovered that if you swipe the app(move it left or right) the apps closes.
I found this interesting and useful; now I don't have to go to the phones task manager to close any apps
