Root Helpppp Pleaseee ! Thanxx c(;
So Finally Got My Phone Working With Cm6 And Its Great Btw ! But How Do I Get NEW Themes And -----> NOT <------ The Ones From The Market ! Pleasee Thanxx I Wuld Appreciate Anyoness Help :} Thanxx:confused:
Did you download the gapps file? If you downloaded and flashed the gapps you will have the market on your phone. We do not condone using sources that use pirated apps.(applanet).
No , Wen I Tried It Said (bad) In Parenthesis And It Said Installation Failed So Im Going to try and reinstall it
