Hero browser not working with WiFi
ayrshiredude
For some reason the browser on my G2 Touch has stopped working with wifi. Its works fine over the air just not when wifi is connected. Everything else works fine with wifi, email, ebuddy etc just not the browser.
Can anyone suggest what I can do?
Thanks
A few things to try....
Clear the browser cache first of all (Settings - Applications - Manage applications - Browser - clear cache). If that doesn't fix it try rebooting the handset or, if still unsuccessful, try disabling "mobile network" to force the use of wifi. Lastly, deleting the wireless connection then reconnecting may fix it.
It did work ok until recently. U have tried deleting the browser history, cache etc but this has not worked. Have tried rebooting as well but nothing. I will try deleting the wireless connection, but as it works fine with everything else, i doubt thats likely to be the issue,
Dont forget, as documented all over this forum a Hero will not pick up on a 'n' standard setting from your router, so if you changed or rebooted your router for some reason lately, it might now be using 'n' standard output.
I was never able to connect to WiFi until I changed the router settings to Mixed (b/g) and now it runs superbly.
