Help Hi New here and need a bit of help
naTas660
Member
Hi, great site, glad to be here.
I have an Admire, I deleted the build.prop file then my phone rebooted and wont come back on.
Then I could not copy the file back with Droid Explorer, may be write protected I guess.
Then I had the smart idea to get to the diag menu and do a system wipe and that disabled debugging so I was not able to connect with droid explorer.
Ware I am now, I am [trying] to use ODIN 1.85.
looks like it adds the port but I get an error:
Code:
can't open the serial com port
I am in download mode also
and one of the usb drivers will not install correctly.
I have searched everywhere for more info on this but haven't had much luck
I would like to fix it just so I know how really, I have replacement in the mail already about 5 days they said.
Thanks for any help
naTas
This is the topic to return your phone to stock
http://androidforums.com/admire-all-things-root/487754-acs-odin-thread-return-stock.html
this will void your warranty (if you restore the android OS using Odin)
for the usb driver you could download it from Samsung site.
Samsung
for not being able to connect the phone, check and make sure the cable is an oem or good cable ... I ran into many problems using a cheap cable.
If you just need to use the phone untill the replacement arrives without voiding your warranty you could use the official Samsung Update to 2.3.6 from here
http://androidforums.com/samsung-admire/454073-regarding-2-3-6-update-metropcs-solved.html
Thanks for the links.
I have drivers for the device but one fails to install and will say unknown device.
I have found I can connect the phone via Droid Explorer when in recovery mode but I have the same problem as before that I cannot change or add any files to the device.
any idea how to change any files.
I had made a backup in system folder of the device a .zip and .back but unable to change the name or extract the .zip to the device.
I have also tried another usb cable [a shorter one]
Thanks again...
naTas
the phone will not boot up, I can get to recovery and download.
I have tried the update.zip and tried to "sign" it but it will not take.
I also read that droid explorer cannot transfer data to a device.
I have used ADB on the device but I no longer have root after the factory recover {I will never do that again, lol] and will not enter SU, if I had SU I could push the file that is missing.
I think the only way to recover the flash would be jtag now, I have never jtaged a phone but have done modems, routers, cable stb etc.
I think I will wait for my replacement now as I do not want to take the phone apart and not be able to get the replacement phone free.
I will try to get an broken phone from CL and test on it if it has the correct chipset for my jtag.
Thanks for all the help everyone and if anyone has any tips please post, I would like to learn jtag to phone as my hobby is getting boring, lol
But I do have to say I have learned allot in the past few days ;)
ohh I forgot to say I can connect to the device with droid explorer and adb in recovery mode but just cant enter SU commands.
I also made sure the update.zip has no .zip.zip and disconnected usb and power off/on pfone...
