Root High Android System Use Fix?
Has anyone tried this lately and can confirm that it works?
[FIX] Wake Issue (Android OS) - Combination of Radio/PRI/NV/Wimax/GPS !Solved
My Android System use is very high and I am wondering if I would get better battery life if I did this fix.
it looks like this fix is for during or after a phone call is made. not sure if that is your issue or not. my android system is not having this issue.
also looks like the fix so far is to turn the proximity sensor to turn off. not sure if that is what you want to do or not.
