This morning I decided to re-install CTMod. After I got everything set up the way I like it, I noticed that it was kinda plowing through the battery. So I charged it up and unplugged it again, and it's still quickly going down. (more quickly than normal, to the tune of about 10% / hour) -- Actually, according to GSam Battery Monitor, it's gone through 9% in 42 minutes. And just switched to 10% in 47 minutes...
Anyway, That's after I rebooted to make sure everything started fresh. So I started looking a little further. I see that CPU Spy is showing zero time in deep sleep since I rebooted. and about 36 of the 50 minutes at 220MHz, which is what I currently have set as the Min Frequency.
So, back to GSam Battery Monitor, I look in the "app sucker" screen, and see that there's not really anything taking a ton of CPU time, but when I look at "Time Held Awake" it's showing that the "kernel (Android OS)" has held the CPU awake for 37m 21s.
I don't believe this is normal, so I decided to boot into recovery and wipe cache and dalvik cache to see if that does anything... Just for kicks I "fixed permissions" too.
So, I'm just gonna let it sit quietly on my desk to see if will go into deep sleep in the next half hour or so....
... Minutes pass ...
It appears to still be draining fairly quickly, and not be going into deep sleep still. Any other suggestions beyond what I've already done?
