The only question I can think of to ask is, are you using an actual locking lock screen or just the slide to unlock lock screen? I would think this only works on the slide to unlock? Other than that, I'm stumped.
The finger pattern unlock I'm using it doesn't unlock that obviously otherwise no point having it is there. Which one is it designed for then?
