@iowabowtech, the problem wasn't adding an icon to the home screen, it was restoring an icon that had been inadvertently deleted from the home screen; that is, it was there one moment, gone the next, I have no idea how; and only slogging through the entire list of apps jogged my memory as to which one had disappeared. There should be an easier way to restore an icon, or even a widget, to the home screen if inadvertently deleted, especially if you can't remember what it was. (And like a lot of people, eventually I think in patterns. Think about it: If you actually dial a phone, do you think through the number every time, or do some numbers just naturally fall under your fingers because you've dialed them so many times? If the latter, you're a pattern dialer. Same things with icons on the home screens on the dinc. You scroll over to one of the seven screens, you tap a location on the screen. Eventually you lose track of what that icon launches, you just know it by position. So I lost the actual icon and couldn't immediately remember which app was in that position. There should be an easier way to restore an icon than traipsing through every app on your device and hoping you remember the missing app.)
