Help Home screen keeps changing
ASAPP
Every time I switch my home screen to a Live Wallpaper - when I shut it down and start again it goes back to the original home screen - not my live wallpaper. How do I keep my live wallpaper up???
are you stock, rooted etc...and which live wp? have you tried other live wallpapers?
And is the wallpaper on the internal or external sd card? I had that problem, then I moved to wallpaper to my internal(the phones) memory and it never happened again.
ahhh yes...good point. any app that had a running feature such as widget or live wallpaper will not work properly if it is moved to the sd card.
